Latest: tebas93089
Overall: 17179
Online Now [103]:
Visitors: 102
Today: 25479
Total: 138545106
Forums › The Car › Solved 206 Problems › light problem
light problem
ableton
PostPosted: Fri Mar 26, 2010 5:13 pm Up
when i press my brakes when the lights are on the rear light on the left side goes off instead of the brake light coming on. anyone know what the problem could be?
Mattie-RS
PostPosted: Fri Mar 26, 2010 5:23 pm Up
most likely a dodgy earth to that light cluster
ableton
PostPosted: Fri Mar 26, 2010 5:34 pm Up
how do i sort that out?
Mattie-RS
PostPosted: Fri Mar 26, 2010 5:36 pm Up
best way is to cut the earth wire in the ligh cluster and run a cable and self tap screw it to the chasis
davidmonkey
PostPosted: Fri Mar 26, 2010 7:08 pm Up
chech the contacts to the bulb are clean and where the plug meets the cluster it may just need cleaning
1.4 8v
Beetlefan
PostPosted: Sat Mar 27, 2010 1:46 pm Up
All it needs is a new stop and tail lamp Wink
:0
ableton
PostPosted: Mon Mar 29, 2010 3:36 pm Up
just put new bulbs in
Beetlefan
PostPosted: Wed Apr 07, 2010 12:28 pm Up
Have We got an update on this? Incidentally My Old lecturer used to say that Bulbs go in the ground,lamps are the things that light up Wink
:0
