Online Now [322]:
Visitors: 321
Today: 98889
Total: 142142313
Forums › The Car › 206 Problems › New 2nd hand car problems
sparks_vfr
PostPosted: Thu Sep 18, 2014 11:18 am Up
Hi All,
have managed to pick up a 1999 206 1.6 for my daughter in pretty good condition, however, there are one or 2 problems.
Main one is there is an intermittent problem sometimes it'll tickover other times not, smells a bit fuelly when it's having these problems.. Have heard that there is a common fault with an idle valve or something like that, have attached a pic (bottom) of what I think it may be, am I right ?
Other problem is there is a breather from the cam cover to the intake pipe... It's goosed, am guessing this could cause tickover probs as well due to it sucking in air ... Any ideas where I can get this pipe from..
Simon
Leegsi
PostPosted: Thu Sep 18, 2014 2:11 pm Up
The second picture is the idle control valve and common to fail
MrRichmond1995
PostPosted: Thu Sep 18, 2014 2:22 pm Up
If you PM me your VIN I will look on service box for you and I will be able to give you a part number.
Nissan Pulsar C13 Owners Club
Mod List:
Lowered 30mm
HEL Braided Brake Lines
EMP Backbox Delete
Full Custom Audio Build
Full LED Light Conversion
30w LED High-Beams
30w LED Fog Lights
Detachable Tow Bar
PostPosted: Fri Sep 19, 2014 6:11 am Up
Yes, the knackered breatherb pipe does need replacing and could cause idling issues.
