Latest: tebas93089
Overall: 17179
Online Now [105]:
Visitors: 105
Today: 4282
Total: 138057799
Forums › The Car › 206 Problems › Air con / heater matrix
mallorcateacher
PostPosted: Sat Aug 02, 2014 1:23 pm Up
Hi!!!
Its hot here in Spain right now and my heater matrix has developed a leak! I suspect its just the O-rings that I need to replace but a more pressing problem is a trip to France in a week.
Would it be possible to disconnect the heater matrix at the bulkhead and bypass that altogether? This way the water would not get to the leak and the air con should still work right?
Thanks in advance for your advice
Adam.
mallorcateacher
PostPosted: Sat Aug 02, 2014 2:57 pm Up
After doing lots of research on the tinterweb the heater matrix and aircon matrix (that the air blows through) are separate. I will get some copper or pvc tubing and bypass the heater matrix in the engine bay then the air con will work just fine!!! Fingers crossed!!
