Latest: airmastertapes
Overall: 17133
Online Now [552]:
Visitors: 551
Today: 13982
Total: 106547624
Forums › The Car › 206 Problems › Cant get it into gear - Lowest gears are the worst ..
bloodmeal
PostPosted: Fri Jul 25, 2014 12:28 pm Up
Suddenly this started happening..
First gear is an absolute nightmare, I sit idling, stamping the clutch, It just will not go in.
Second gear seems slightly slightly easier, so I have to start in second, third is the easiest of all.
If I cant fix this I may aswell break up this pretty 206 - as the modified parts and styling pieces are probably worth more than the 2002 138 gti it's self.
PostPosted: Fri Jul 25, 2014 12:40 pm Up
Check the gear change 'linkages' aren't worn on the gearbox.
DeadEyePaul
PostPosted: Sat Jul 26, 2014 3:14 am Up
Try this? Put it in gear with the engine off and the clutch held in. Then start the engine and release the clutch. If that doesnt work then you've bent a rod in the gearbox
bloodmeal
PostPosted: Sun Aug 10, 2014 5:48 am Up
it goes in when the car's not running without any problem at all.
PostPosted: Mon Aug 11, 2014 12:53 am Up
Might be the first motion shaft has failed or as simple as a clutch
bloodmeal
PostPosted: Mon Aug 11, 2014 12:39 pm Up
taking it to a mechanic tomorrow and just hoping i dont get stung for a lot of cashola... Sad
