Latest: airmastertapes
Overall: 17133
Online Now [214]:
Visitors: 213
Today: 12896
Total: 106677142
Forums › The Car › 206 Problems › Hot air in footwell
Hot air in footwell
shaw26
PostPosted: Mon Jul 28, 2014 4:42 am Up
I'm having a problem with the heater (I think) even when all the heating is turned off and set to the lowest temp hot air still comes from the footwell.
It's annoying because in this heat it makes driving worse!
Anyone had the same problem?
Dodgernator
PostPosted: Mon Jul 28, 2014 12:33 pm Up
If it's manual controlled check that the cable is closing the air ducts properly and that the dial is set to cold. It's normal for a little blow in the foot wells.
shaw26
PostPosted: Tue Jul 29, 2014 3:14 am Up
it's the electronic unit, should of said in my first post.
Dodgernator
PostPosted: Tue Jul 29, 2014 3:31 am Up
You could try blocking it off?
