Latest: cogeim7
Overall: 17185
Online Now [427]:
Visitors: 426
Today: 131602
Total: 147428082
Forums › The Car › 206 Talk › oil indicator
oil indicator
Forum Index › 206 Talk
petem
PostPosted: Wed Aug 13, 2014 9:19 am Up
Hi. The oil indicator that comes on the dash when you first turn on the ignition says my oil level is at minimum. but after topping up and checking the dipstick, my level seems fine. any ideas?
PostPosted: Wed Aug 13, 2014 11:14 am Up
Depends on age of 206, if its multiplexed it also depends on what BSI software version is currently installed.
There not that great even when working correctly, use the dipstick as its a much more accurate reading.
Vexs
PostPosted: Wed Aug 13, 2014 2:35 pm Up
Mine's been faulty for a little while now and it's never caused any problems, suspect it's senor related fault but wouldn't use it even if it did work correctly. Nothing wrong with the old fashioned way.
My GTI 180
My Old 1.4 8v
southwestchap
PostPosted: Thu Aug 14, 2014 6:41 am Up
Don't rely on it, sometimes I get full of oil, another time its empty although its fine on the dipstick.
PostPosted: Fri Aug 15, 2014 1:29 am Up
With age,and miles,i guess the sensor is not accurate as if it was bran new,and if the previous owner/s been using the oil for a very long mileage,i think a cleaning or replacing the oil sensor can fix that,also what MrBSI said about BSI software have to be considered as well.
America
PostPosted: Sat Aug 16, 2014 5:23 pm Up
My dash indicator is only accurate when I first start it in the morning. I check the dipstick everyday anyway no matter what the indicator says.
