Online Now [184]:
Visitors: 184
Today: 29690
Total: 138708857
Forums › The Car › 206 Problems › Random Misfire
Random Misfire
Ozzy094
PostPosted: Sun Aug 03, 2014 10:57 am Up
Had this problem a few times now.
Was driving down a dual carriageway, then all of a sudden would get a loss of power (as if i were braking) and the engine warning light flashes, along with juddering etc.
Took it to the garage and had the coils and sparks replaced, but after a week (90 odd miles) its done it again.
Any idea as to what exactly may be the problem?
Geforce
PostPosted: Mon Aug 04, 2014 12:38 am Up
I'm having a similar problem. I also changed coils. I'm gonna change map sensor next
Ozzy094
PostPosted: Mon Aug 04, 2014 12:40 pm Up
I have a sneaky feeling it's injector related, so I may dive into fixing that, but please do keep me updated if the map sensor change does fix the problem for you!
Geforce
PostPosted: Mon Aug 04, 2014 4:34 pm Up
Change of plan. Changing fuel filter instead then map sensor if no luck
Ozzy094
PostPosted: Wed Aug 06, 2014 1:59 pm Up
Awesome, please keep me updated on the results!
206Info_SW_Scots
PostPosted: Mon Aug 11, 2014 9:11 am Up
I had an erratic misfire, picked up the correct code with a Bluetooth OBD sensor I bought for a fiver, and it turned out to be one faulty injector. The one below the squirter. Which, after research on here, seemed to be #common#.
206 SW 55 Plate - Happy Owner
Ozzy094
PostPosted: Sun Aug 17, 2014 6:39 am Up
Awesome thanks for the info! I bought a Redex injector cleaner last week and it seems to have solved it for now, fingers crossed it doesn't do it again
PostPosted: Mon Aug 18, 2014 10:14 am Up
get the codes read. Having a guess and changing parts, especially if you are a relative novice at diagnostics, and hoping you have guessed right is quickly very expensive and time consuming.
