Latest: cogeim7
Overall: 17185
Online Now [483]:
Visitors: 482
Today: 55146
Total: 147572370
Forums › The Car › 206 Problems › Glove box light
Glove box light
ARRAN
PostPosted: Mon Sep 26, 2011 7:03 am Up
Popped my glove box light out earlier as it wasnt working, expecting it to be a bulb or something.. but it had no wires running to it at all. I tried to locate the plug which plugs into the light itself, but couldn't find anything behind the glove box. Any suggestions on where it could be lol?
See my project here.
PostPosted: Mon Sep 26, 2011 7:04 am Up
pop the hu out and have a look that way see if there are any free plugs hanging around near glove box. or tapped up.
ARRAN
PostPosted: Mon Sep 26, 2011 7:09 am Up
Okay, thanks Very Happy
iainlovatt
PostPosted: Mon Sep 26, 2011 8:06 am Up
take a pic and show us, sounds like it doesnt have one, but the wires should be there..
There shoiuld also be a push clip sensor thing bottom right of the glove box frame when you open the door which activates the light!!
(My Garage)
ARRAN
PostPosted: Mon Sep 26, 2011 10:34 am Up
Its all there, the lense just pops out, but it has a socket in the back which it looks like something plugs into
PostPosted: Mon Sep 26, 2011 11:07 am Up
A white connector plug with 2 wires in.
Should also be a brown connector plug for the switch.
Normally clipped to right hand side of glovebox housing if not factory fitted, stick your hand up the back of the dash & have a feel.
iainlovatt
PostPosted: Tue Sep 27, 2011 3:53 am Up
you sort it buddy?
(My Garage)
ARRAN
PostPosted: Tue Sep 27, 2011 12:34 pm Up
Havent had a chance to look yet mate, will have a look tomorrow Very Happy
nemesislee
PostPosted: Fri Aug 29, 2014 10:27 am Up
I brought a boot light and a hand brake switch from ebay but can only connect up one as I have two connectors at the side of my glove box but only the brown connects to them both. and ideas or is it that you cant use the hand brake switch for the glove box switch?
thanks
peugeot 206 silver 1.4ltr lx
PostPosted: Fri Aug 29, 2014 12:15 pm Up
Just buy a glovebox switch from the dealers. I bought both the light and the switch and came to about a fiver. Bit dearer without discounts.
Note sure if the pre-plex is any different to the multi-plex so it would probably be easier to check prices on servicebox before going to the dealer with part numbers.
