Online Now [381]:
Visitors: 380
Today: 47387
Total: 142191563
Forums › The Car › 206 Problems › Power steering Plug
Power steering Plug
rict1883
PostPosted: Wed Aug 20, 2014 4:13 pm Up
I have a leak coming from the power steering hose, there is a wired plug fitted where it seems to be leaking from
is there a rubber seal that could be replaced or is it a new hose
2006 206 1.6
PostPosted: Wed Aug 20, 2014 4:25 pm Up
Sounds like it's leaking from the pressure sensor. If you can't buy a seal a new sensor might come with one.
rict1883
PostPosted: Thu Aug 21, 2014 11:03 am Up
ive looked at a few new sensors for sale and they do not look like it comes with a seal
PostPosted: Thu Aug 21, 2014 11:30 am Up
The seal for the power steering pressure switch that screws in to the pipework is available on it's own from any Peugeot / Citroen main dealer for under £2.
rict1883
PostPosted: Thu Aug 21, 2014 11:41 am Up
thank you MrBSI
ive just read that it could be the actual sensor that has gone and it leaks through this, will change washer first and take it from there
