Online Now [291]:
Visitors: 290
Today: 13600
Total: 143431378
Forums › The Car › 206 Problems › Engine light no fault codes
Project2062014
PostPosted: Wed Aug 20, 2014 1:20 pm Up
Engine light is on but no fault codes ?
PostPosted: Wed Aug 20, 2014 1:33 pm Up
What are you using to scan?
Generic code reader OR Peugeot Planet?
Project2062014
PostPosted: Thu Aug 21, 2014 3:13 am Up
Using obd2 blue tooth connector with the torque app on my phone . Has picked up cat issues picks up when i unplug a lead
. Defo all works .
PostPosted: Thu Aug 21, 2014 3:55 am Up
It may not pick up the manufacturer specific codes (P1xxx) and will only pick up the generic codes (P0xxx), depends on the software. Never used torque app so don't know how accurate it is, but chances are if it's free, then it won't be top notch and may only work properly if you have a paid version.
stuarts30
PostPosted: Thu Aug 21, 2014 6:57 am Up
From previously using the torque pro app and then making the move to pp2000 i can safely say that the torque pro app will not pick up all codes.
Where are you based, i would happily run a scan for you if you are local to the morden, surrey area.
Project2062014
PostPosted: Thu Aug 21, 2014 12:45 pm Up
. Its the pro version app . Im based in cornwall otherwise id be happy to let you read it .What tool (s) software do i need to completely read the ecu change setting ie .a/f voltage also read all reatime data if possible . To have the same control as peugeot has . Ive seen a kwp2000 & separate software on flebay . .peugeot planet ?
PostPosted: Thu Aug 21, 2014 1:07 pm Up
Peugeot Planet was the proper official Peugeot dealer diagnostic software & it will ONLY work with the Lexia ( cloned ) interface.
The software you can find free on the internet, it's the interface you pay for.
Planet only really work's on Windows XP, the newer & current program is called Diagbox ( but its backward compatible to read a 206 ) & that will run on Windows 7.
Project2062014
PostPosted: Thu Aug 21, 2014 9:25 pm Up
Ok cheers for the info . Torque app has now picked bank sensor 2 . Il sort that out . Just a lambra sensor failed ..
Going to buy the lexia interface got a cheep xp 32bit laptop off ebay & software to write maps . What do i need to remap ? . This is where the kwp2000 to flash the ecu with the remap ? . Will peugeot planet allow me to change ignition timing ? Fuel rail voltage map sensor voltage etc does anyone know ? . Cheers B
PostPosted: Fri Aug 22, 2014 9:10 am Up
Excess fuel can knacker lambda sensors. the root cause may not be the failed sensor but another fault that has now killed the lambda.
Some lambda faults at early stage of sensor failure on some cars will light the engine management light without storing a code.
Summary: root cause of the engine light may or may not be the lambda sensor.
