Online Now [56]:
Visitors: 55
Today: 110697
Total: 105439087
Forums › The Car › 206 Talk › Clutch replacement
Clutch replacement
DjSerious
PostPosted: Fri Aug 22, 2014 7:56 am Up
Do you have to take both driveshafts out the replace a 3 piece clutch kit? Is it worth doing all at same time to save on labour costs having all dine separate?
southwestchap
PostPosted: Fri Aug 22, 2014 9:18 am Up
The three pieces are the friction plate, pressure plate and the thrust bearing and it all gets fitted together as one job.
I can confirm you will need to remove both drive shafts. Well you could leave the drivers side one in but you would struggle to refit the box.
DjSerious
PostPosted: Fri Aug 22, 2014 10:25 am Up
Thanks!! I've got 2 upgraded shafts both driver and passenger now it wnt cost a penny extra if I have them fitted the same time as my clutch!! Wink
Project2062014
PostPosted: Fri Aug 22, 2014 6:07 pm Up
It will cost more as its more work .
