Latest: morgan20
Overall: 17135
Online Now [424]:
Visitors: 423
Today: 59799
Total: 110611826
Forums › The Car › 206 Problems › Key
Key
Deano
PostPosted: Sun Aug 24, 2014 10:34 am Up
Hi everyone can I just pick your brains. Got a 206 140 02 reg right what's happened is my button to open doors had fell threw so I got another key off eBay it only came with shell n a blade so I put my chip in my motherboard and my key in but the problem is on the mother board the close button has a little nipple on it but the one off the open has gone so the open button still does not work is the mother board connected to ignition, Central locking or ecu or is that just the key and chip so my question is ? Can I buy a key off eBay with mother board in and will it work any answers much appreciated cheers fellas
PostPosted: Sun Aug 24, 2014 10:41 am Up
I think I counted three bits of punctuation in that huge sentence.
PostPosted: Sun Aug 24, 2014 11:20 am Up
After hurting my eyes reading that, No, you can't just buy another board from ebay and use it. It will need pairing using PP2000.
PS there are about 5 different boards for a multi-plex.
PostPosted: Sun Aug 24, 2014 11:22 am Up
Just get the button replaced on the pcb, either do it yourself OR send the key of & have a professional replace it.
PostPosted: Sun Aug 24, 2014 3:19 pm Up
What He Said ...you will find a repair kit on Ebay.better than buying a new key.
Deano
PostPosted: Sun Aug 24, 2014 3:49 pm Up
Thank you mr bsi, and tommo.
Edward I was asking I about a key not to sit there n count my punctuation marks cheers.
I was in work and had to wright it quick it's just like a text
Do u use punctuation In texts.!!!!
And macca if your eyes hurt reading that I suggest a trip to spec savers .lol
L5_UKS
PostPosted: Mon Aug 25, 2014 4:30 am Up
I use punctuation in my texts?
astra_aurelis
PostPosted: Sun Aug 31, 2014 6:45 am Up
I would have just replaced the button instead of that crap you did!
Deano
PostPosted: Sun Aug 31, 2014 11:59 am Up
I did replace the button on the case. But did not know the little bit inside was broke aswell so how's all what I did crap u mong.
PostPosted: Tue Sep 09, 2014 2:15 pm Up
L5_UKS has anyone answered your question?
