Online Now [1113]:
Visitors: 1112
Today: 72559
Total: 106409795
Forums › The Car › 206 Talk › Air con removal
Air con removal
Steve137
PostPosted: Sun Aug 31, 2014 5:44 pm Up
hi everyone im currently in the process of stripping my car, next job is to remove all air con pipes,rad and pump. but im worried i wont be able to find an auxilery belt to fit can anyone enlighten me on which one to use, car is a 2.0 gti 137.
thanks steve
PezHdi
PostPosted: Sun Aug 31, 2014 6:45 pm Up
Iv done mine on my HDi.
We basically got a new belt what we thought would fit and then just kept swapping it till we got the right one. Also you could get a piece of string and run it around the pulleys and mark where it joins and you will have a size you can measure Smile
Hope this helps Smile
EXL Pez
iainlovatt
PostPosted: Mon Sep 01, 2014 4:41 am Up
leave the aircon pipes till last! They are a pain. You can remove the dryer and condenser, but its you wont be-able to remove the pipes without dropping the engine down to get to one of the bolts!
(My Garage)
PostPosted: Mon Sep 01, 2014 8:25 am Up
Just go to peugeot, they list a belt for the GTi without aircon.
Part number is: 5750 VH
Price: £15.40 EX VAT
£18.48 Inc VAT
Steve137
PostPosted: Mon Sep 01, 2014 11:21 am Up
£18.48 Inc VAT
thanks mate will go to peugeot and see if they have one
PostPosted: Mon Sep 01, 2014 12:19 pm Up
I've got a belt that's only done 1k miles before I binned the PAS pump too. It's a gates belt from the Peugeot dealer.
