Latest: tbafonso
Overall: 17130
Online Now [315]:
Visitors: 314
Today: 4019
Total: 103934461
Forums › The Car › 206 Problems › Somethings fallen off the bottom of my 206...
lauraa94x
PostPosted: Sun Sep 21, 2014 10:15 am Up
Hi all, new to the forum!
I bought my 2001 1.4 glx 206 last October, no problems with it until now. Mum's just moved it off the driveway and this was underneath - I know its a real long shot but don't know if anyone knows what it could be? It's got an MOT in a matter of weeks and need to cover some miles soon before the MOT so as I know next to nothing about cars I wanted to check...
Thanks all Smile
Got people saying it could be something from my exhaust, someone saying connector for battery.... pretty confused!!
PostPosted: Mon Sep 22, 2014 3:15 am Up
Laura - no photo showing.
mtempsch
PostPosted: Mon Sep 22, 2014 3:46 am Up
They work for me (Windows XP. latest Firefox).
Links are
http://s922.photobucket.com/user/lauraa94x/media/936687_10203513623858678_627700927561106172_n_zps8e61d52b.jpg.html and http://s922.photobucket.com/user/lauraa94x/media/10696338_10203513624058683_7221895013846163773_n_zpsdca7d749.jpg.html
Can't identify the piece, though it doesn't look like any battery connector I've ever seen.
Silvermetallic 2004 206 RC
badj
PostPosted: Mon Sep 22, 2014 4:56 am Up
Looks like it's made of plastic, so not much chance of it being a battery connector or exhaust part (if it is, plastic, as it'd be a bit unsuitable).
It looks like the pivot for the throttle cable or a sensor - it's the broken part that makes me think that.
Iceland Blue '99 206 GTI (140) - SOLD
KMF '05 1.4 HDi
PostPosted: Mon Sep 22, 2014 4:59 am Up
Near where the front pipe joins the centre pipe, there is a clamp that attaches to the gearbox, but it looks too heavy duty for that.
My first thought was there is a little loop near the rear shock absorber lower mounting, but doesn't have the angle like this piece. My only other thought would be the lifting loop on the cylinder head.
It's the hollow piece riveted to it that's confusing
Out of curiosity, what's the diameter of the hole? Difficult to tell sizes from the photos
Vexs
PostPosted: Mon Sep 22, 2014 6:58 am Up
Could it be a front or rear bumper brackets? You know the two on either end that bolt up to the frame is it to stop it moving and flexing all over the place?
My GTI 180
My Old 1.4 8v
Project2062014
PostPosted: Tue Sep 23, 2014 3:04 am Up
Looks kinda like a seat belt fixing . & it dont look like its off a 206 . I wouldnt worry . Run the m.o.t ! Will pick up any issues if your still worried .
badj
PostPosted: Tue Sep 23, 2014 3:15 am Up
I don't think anyone's mad enough to make a seat belt anchor out of plastic, but I would agree that it doesn't look like anything off a 206 that I know of.
KMF '05 1.4 HDi
Shadowstalke
PostPosted: Tue Sep 23, 2014 6:53 am Up
The fact the all-metal end has no damage at all on it suggests to me that it is not connected at that end at all when it was on the car (I'd expect at least a little rubbing/wear or some signs of bearing damage if it was). So that end for me is "free" when it is attached to the car.
That means either this big, solid bit of metal that could be used for attaching something solid to, or lifting something is only held on the car by whatever that plastic thing is (I know French designers aren't smart, but using plastic as a structural strong point - that is pushing the limits of a sane man's sensibilities!!) or the bolt/rivet that passess through the plastic bit should also have gone into some other significant part of the car. I think this is the case, and that that rivet has failed (possibly due to the same impact/force that snapped the plastic). Look around for something that looks like a hole that's been filled in (as it was a hole, and the rest of the bolt/rive is still in there!).
My money would be on a head/block lifting eye, or some sort of a a towing eye
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
badj
PostPosted: Tue Sep 23, 2014 7:19 am Up
As per what I've originally said, I don't think that is metal at all - more 'dirty' black plastic.
The first picture has moulding seams on that part - you wouldn't get that at all (or, shouldn't) if it were made of metal.
KMF '05 1.4 HDi
