Latest: jackrox1992
Overall: 17186
Online Now [506]:
Visitors: 505
Today: 233241
Total: 148159518
Forums › The Car › 206 Talk › Changing rear bulbs
Changing rear bulbs
Forum Index › 206 Talk
206Mark007
PostPosted: Fri Sep 26, 2014 11:51 am Up
Can someone please talk me through how you change the rear reversing lights. I take it you have to take the clusters out but cant get access to them
badj
PostPosted: Fri Sep 26, 2014 11:58 am Up
If you pull back the carpet either side you'll see a black plastic wing nut by the wiring connector. Undo those and the lights will pull out giving you access to the bulbs
Iceland Blue '99 206 GTI (140) - SOLD
KMF '05 1.4 HDi
206Mark007
PostPosted: Fri Sep 26, 2014 12:00 pm Up
So its just 1 nut on each light?
badj
PostPosted: Fri Sep 26, 2014 12:25 pm Up
Yup.
There's only a locating lug for the furthermost side. Just undo the one plastic nut and it'll come free - it might need a bit of a wiggle, as the weather/moss tends to keep them securely in place!
KMF '05 1.4 HDi
gazza82
PostPosted: Fri Sep 26, 2014 6:24 pm Up
Mind the locating pin that fits into the wing/body at the frontmost corner ...
206Mark007
PostPosted: Sat Sep 27, 2014 9:47 am Up
All sorted cheers, changed reverse light but still not working Sad must be a fuse
badj
PostPosted: Sat Sep 27, 2014 10:11 am Up
Probably the switch on the gearbox.
Common to fail tbh
You don't need a reverse light for MOT, so depends how much it bothers you.
KMF '05 1.4 HDi
206Mark007
PostPosted: Sat Sep 27, 2014 10:15 am Up
Common to fail tbh
Its gf's car would rather it work than not. Ill get the switch looked at too. Cheers for the heads up
badj
PostPosted: Sat Sep 27, 2014 10:39 am Up
206Mark007 wrote:
Common to fail tbh
Easiest way to check would be to disconnect the plug from the reverse switch and bridge the contacts.
KMF '05 1.4 HDi
