Online Now [544]:
Visitors: 543
Today: 59480
Total: 105101792
Forums › The Car › 206 Problems › Dipped Headlight problems - 206 04 plate
Go to page Previous  1, 2
PostPosted: Wed Oct 15, 2014 1:33 pm Up
DREWDEN wrote:
If power is getting to the fuses, and not getting to the lights, logicaly it would point to the headlight switch being at fault.
The tell tale is coming on, and power is reaching the fuses, which would suggest it's not the switch.
Here is the wiring diagram for the multi-plexed headlights. It might narrow down the cause.
If power is reaching the fuses, then I'd do a continuity check between the fusebox and the headlamps, although you'd be unlucky to have both circuiys develop a fault at the same time.
Page 2 of 2
