Latest: Stu-mill
Overall: 17131
Online Now [146]:
Visitors: 145
Today: 28796
Total: 104665067
Forums › The Car › 206 Problems › 2002 1.1 won't start
Charliew
PostPosted: Sun Oct 12, 2014 4:15 am Up
Hi all I have a 2002 1.1 8v 206 , the last engine cracked the block so I bought a replacement out if a same year Saxo 1.1 , changed every thing over flywheel gearbox all the sensors , loom everything bar the head and block , put it all back together and won't start , broke out the code reader came up with cylinder 1,2,3,4 injector malfunction , code is current on cranking , fine all my pin outs back the the ecu , all ok , load tested wiring all ok , loaf tested little rubber loom on injectors , all ok , got good fuel pressure just not injecting , splash of easy start and it barks up and dies , anyone had this problem ??
Seatock789
PostPosted: Sun Oct 12, 2014 11:22 am Up
Is there a fuel cut off switch that needs to be re-set?
