Online Now [571]:
Visitors: 570
Today: 115265
Total: 105692162
Forums › The Car › 206 Problems › aircon can i delete ?
bridgwaterlee
PostPosted: Thu Oct 16, 2014 2:50 pm Up
Hi can anyone tell me can I remove the aircon and pipes and if so what do I need to do and what bout the belt? Any help would be great . Thanks Lee
PostPosted: Thu Oct 16, 2014 3:43 pm Up
You can bin it all and just use a shorter belt.
bridgwaterlee
PostPosted: Thu Oct 16, 2014 3:48 pm Up
thanks mate , do they do a no aircon belt and wot bout aircon rad?
iainlovatt
PostPosted: Fri Oct 17, 2014 7:25 am Up
to undo all the pipes you need to remove subframe and drop engine. If your not bothered cut them off, easiest option.
(My Garage)
PostPosted: Fri Oct 17, 2014 10:37 am Up
I cut mine out. Couple of cuts at most and some brackets to remove and it's all out. Just tilt the coolant radiator back to slide the air con unit out. Somebody will find you the part number for a non AC belt. Euro car parts list them too. You'll save a huge 10kg by removing everything.
PostPosted: Fri Oct 17, 2014 12:13 pm Up
Why you take the aircon off,I'm wondering!!!
PostPosted: Fri Oct 17, 2014 12:26 pm Up
Normally to loose the excess weight.
Also a lot of people don't understand how air con works & think there saving money by leaving the AC switched off & opening the window Laughing
PostPosted: Mon Oct 20, 2014 2:49 pm Up
I see...good point MrBSI Smile Wink
bridgwaterlee
PostPosted: Mon Oct 20, 2014 4:36 pm Up
Thanks for help everyone am still quite new to everyone even tho done few shows and was at donington with vexa will try and sort some pics on site soon . Lee
