Latest: lio94
Overall: 17181
Online Now [137]:
Visitors: 136
Today: 28997
Total: 141584387
Forums › The Car › Solved 206 Problems › hOW DO i ACCESS THE REAR FOG LIGHT BULB
m.killeavy
PostPosted: Sun Apr 11, 2010 8:39 am Up
i'VE REMOVED rear fog light assembley but can't locate securing pin as mentioned in manual, which part is it?
206 1.6 Roland Garros
amy-v17
PostPosted: Sun Apr 11, 2010 8:42 am Up
There should be clip it should be easy to see but I had to flick mine up with a screwdriver, if you have the foglight out all you have to do is twist the bulb and it should come out
Dabamash
PostPosted: Sun Apr 11, 2010 9:06 am Up
Staff - Daba
I used a flashlight to have a look under, then just pushed a little metal tab on the right hand side, and it just popped out. Was a 5 second job.
The bulb just twists out.
m.killeavy
PostPosted: Sun Apr 11, 2010 12:21 pm Up
Hi Everyone, thanks for the help, was easy in the end as you said. Just had to apply more pressure. Working fine now.
