Forums › The Car › 206 Talk › wondering Exhaust manifold DW into EW |
Posted: Fri Nov 21, 2014 8:57 am |
As we all know
"The EW/DW uses many parts from the XU, most notably the crankshaft, but is built with lighter materials. The EW name is used for the petrol engines ("e" for essence) and DW for Diesel engines." wikipedia
reason i ask is because as we know xu10 can even use the diesel crank to up the cc
this also goes into BMW where easily turbo charge their petrol engine using diesel manifold, cheap option.
www.e30tech.com/forum/...hp?t=43911
if this fit, possible means can easily boost our engine,
Posted: Fri Nov 21, 2014 11:16 am |
What shape ports are on the DW? Will the DW manifold be able to flow enough for a higher revving petrol engine?
Posted: Sat Nov 22, 2014 3:06 pm |
| Edward wrote: |
| What shape ports are on the DW? Will the DW manifold be able to flow enough for a higher revving petrol engine? |
not sure Edward, wondering if anyone could test fit it.
no diesel model in Malaysia , thats why im asking
Posted: Sat Nov 22, 2014 3:11 pm |
i look over the manifold picture, look nearly fit, not sure though
