Latest: tbafonso
Overall: 17130
Online Now [425]:
Visitors: 424
Today: 53940
Total: 103170690
Forums › The Car › 206 Problems › 206 Oli filter housing full of oil
Fredthenewt
PostPosted: Sat Nov 15, 2014 12:12 pm Up
Dear All, I have just changed the oil on my daughter's 206 1.4 petrol. I drained the sump before I removed the filter and was surprised to see the filter housing was still full of oil - I had to drain it with a syringe. Is this normal? The car runs fine and sounds good.
Many thanks.
PostPosted: Sat Nov 15, 2014 12:55 pm Up
Quite normal yes.
PostPosted: Sat Nov 15, 2014 1:10 pm Up
Funny enough, yes
Fredthenewt
PostPosted: Sat Nov 15, 2014 3:52 pm Up
Most grateful
