Latest: lio94
Overall: 17181
Online Now [155]:
Visitors: 154
Today: 26226
Total: 141976804
Forums › The Car › 206 Talk › Clutch change on a 2.0 HDI
DeeTurbo
PostPosted: Fri Nov 21, 2014 1:24 pm Up
Hi guys,
I'm going to change the clutch on my girlfriends 206 2.0 HDI this weekend.
I've done one on a 306 HDI before and I was wondering is there much difference in the job I need to look out for and does anyone know of a guide, I've had a search but can't find anything?
PostPosted: Fri Nov 21, 2014 2:52 pm Up
Only difference really between the 306 & 206 is the 306 runs a cable clutch and the 206 runs a hydrolic setup so no cable but a slave cylinder to play with instead.
DeeTurbo
PostPosted: Fri Nov 21, 2014 4:55 pm Up
Thanks for your reply.
Isn't the slave cylinder bolted to the engine block?
Does the cylinder get in the way at all?
PostPosted: Fri Nov 21, 2014 5:27 pm Up
No it's bolted to the box, only 2 little allan bolts, just unbolt it and put it to one side, just be careful not to bend the pipe too much.
DeeTurbo
PostPosted: Fri Nov 21, 2014 5:38 pm Up
Awesome stuff, hopefully it'll be nice and straight forward. Just need to remember to put the plate in the right way.
DeeTurbo
PostPosted: Sat Nov 22, 2014 8:47 am Up
Quick question about the slave cylinder, if I let it extend out will the piston pop out or is it held in by a circlip to stop it from popping out?
wifes206
PostPosted: Sun Nov 23, 2014 10:30 am Up
When unbolt from front of gearbox just keep hands on it while extends.
But it does stop n not pop out!
206 2.0hdi(04)
southwestchap
PostPosted: Mon Nov 24, 2014 6:28 am Up
Not necessary but I removed the radiator when I done mine. Just to lessen the risk of catching it as it is fairly tight when lifting the box out.
slave cylinder is fine fully extended.
