Posted: Mon Dec 08, 2014 2:02 pm |
Hi gazza yes the central locking works fine, also I had been driving around fine for 2 days.
I have just put the multifunction relay back in and reconnected the battery and the fuel pump is now priming, and fuel comes through the pressure valve on the fuel rail. But still does not start
Also no the chip board is still in the key and I have changed the battery just incase
The red light on the key flashes very quick when pressed, is this normal?
Posted: Mon Dec 08, 2014 2:23 pm |
The chip isn't on the board, it's loose in the fob so easily lost.
Are you Darwen or Dingle side of Blackburn? Not sure what I'm doing Friday so may be able to get over with PP2000 then.
Posted: Mon Dec 08, 2014 3:05 pm |
I'm up at guide near the willows eatery, I am working on Friday until 8pm. Is there any other day that is good for you. The key was not taken apart while I was driving it, it was only the next day after the car wouldn't start that I removed the battery, I'll check the key now.
| 1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170 | |
Posted: Mon Dec 08, 2014 3:08 pm |
Just checked and the chip is underneath the circuit board and has cp wrote on it.
Posted: Mon Dec 08, 2014 5:03 pm |
You do realise a pump only primes on petrol for 3 seconds? Then continues once started?
| Team Impossible Possible
Posted: Mon Dec 08, 2014 5:22 pm |
206gt160 wrote: |
When I put the key in the ignition with the door open it makes no bleeping.. if this helps |
Transponder Ariel around the ignition barrel playing up and not recognizing the key?
Posted: Mon Dec 08, 2014 5:56 pm |
Checked your earth straps?
Posted: Tue Dec 09, 2014 3:19 am |
206gt160 wrote: |
I'm up at guide near the willows eatery, I am working on Friday until 8pm. Is there any other day that is good for you. |
Unfortunately not. Got baby sitting duties this week. Would have to be daytime Friday as I am duty manager from 6pm Friday night until 2am Monday morning, so got to be within 20 minutes of home just in case.
Posted: Tue Dec 09, 2014 6:32 am |
Sounds like the immobiliser isn't being disarmed.
Find someone with Peugeot Planet.
Posted: Tue Dec 09, 2014 7:27 am |
Addaz wrote: |
You do realise a pump only primes on petrol for 3 seconds? Then continues once started? |
Hey pal yes I realise it is only a few seconds, I just thought I remembered it being louder. The new pump is how I remembered it and louder than the old one. The old pump was very quiet and had to have the seats up and be close to it to hear anything.
Posted: Tue Dec 09, 2014 7:29 am |
LeeThr wrote: |
206gt160 wrote: |
Transponder Ariel around the ignition barrel playing up and not recognizing the key? |
I haven't been in the car for a while due to it being off the road, should I hear a beeping noise with the keys in and doors open? Or just a beeping with the lights on and door open. It's been that long I can't remember.
Posted: Tue Dec 09, 2014 7:32 am |
Steve206 wrote: |
Checked your earth straps? |
Not as of yet I was going to do them today but the mrs ended up wanting to go in town after our scan at the hospital.
Which ones are the main culprits? The one on the top of L/H strut, the one on the gearbox? Probably best tracing the negative lead of the battery and removing them all cleaning them up, or is there more than that.
Posted: Tue Dec 09, 2014 7:36 am |
macca1411 wrote: |
206gt160 wrote: |
Unfortunately not. Got baby sitting duties this week. Would have to be daytime Friday as I am duty manager from 6pm Friday night until 2am Monday morning, so got to be within 20 minutes of home just in case. |
I will get all the earths checked and try the imobiliser reset again and see if the problem persists, I will be working Friday 7am until 19:50 until I finish for Christmas on the 19th. Hopefully I will be able to solve the problem with out diagnostics, fingers crossed. I will check all sensor voltages and give them a clean up. After removing the multifunction relay and having the battery disconnected for a good 2 or 3 hours then reconnecting everything, the fuel pump started to prime again. Need to check the coils are sparking properly.
I will also check the battery voltage see if the reading are correct
Posted: Tue Dec 09, 2014 7:38 am |
MrBSI wrote: |
Find someone with Peugeot Planet. |
Is pp2000 the only way of unlocking the bsi? I thought there was a way of doing it with the windows down battery off etc, I may be thinking of the imobiliser reset.
Thanks guys for all the replies it's all good info for me to go and try on the car.
Posted: Tue Dec 09, 2014 7:45 am |
LeeThr wrote: |
206gt160 wrote: |
How would this be solved? New transponder Ariel and then new Ariel and my key coded with pp2000?
