Latest: lio94
Overall: 17181
Online Now [233]:
Visitors: 232
Today: 61956
Total: 141617314
Forums › The Car › 206 Problems › mis in engine
mis in engine
DAVERS
PostPosted: Thu Feb 05, 2015 3:03 pm Up
hi guys great site here i hope you can help me i have a 2003 1.1 206 its a great wee car but recent it has got a mis in the engine i got it plugged in and it came up a detected misfire so i done compression test all 100% changed timing belt and went as far as head gasket then coil pack even changed injector rail put all back together and still a miss in engine have ye and idea what could be wrong this problem has me beaten any help would be appreciated thankyou
DAVERS
sean.r.steward
PostPosted: Thu Feb 05, 2015 5:17 pm Up
Where did it go lmao sorry couldnt help my self
Could be mixture
could be air leaks/exhaust leak ie around o2 or before
Hawkers
PostPosted: Fri Feb 06, 2015 1:17 pm Up
So you got the codes read, which told you to change the timing belt, coil pack and injector rail but it didn't fix the problem. What did you scan it with?!
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
PostPosted: Fri Feb 06, 2015 6:45 pm Up
Remove and check colour of plugs. If it is the same cylinder misfiring that plug is likely to be a different colour.
Alternatively buy an infra red heat sensor and run the engine. Measure the temp of each exhaust manifold and the one that is cooler will be the cylinder with the misfire. That gives you a starting point.
Did you really change all that before you tried a set of plugs? What do you mean by compression test 100%. What were the readings? Who did the check? Was it a wet and dry test?
What codes showed when you read them? Have you cleared and re-read the codes?
