Latest: cogeim7
Overall: 17185
Online Now [590]:
Visitors: 590
Today: 216801
Total: 147492287
Forums › The Car › 206 Problems › heated rear windscreen
jojojo
PostPosted: Tue Dec 16, 2014 6:13 pm Up
Hi can anyone tell me where the relay is for rear windscreen please? And wheres the best place to buy one from please?
DREWDEN
PostPosted: Wed Dec 17, 2014 8:53 am Up
Have you checked the fuse, in the fuse box under the steering wheel, preplex has a 30amp fuse.
206 2ltr Hdi glx 53 plate
jojojo
PostPosted: Wed Dec 17, 2014 5:29 pm Up
I can't find which one it is in fuse box but the little orange light next to button glows even when ignition off.
PostPosted: Thu Dec 18, 2014 1:10 am Up
Have you checked if the rear screen is live with ignition off? Probably have a flat battery if it is.
If the only symptom you are getting is the tell tale on the heater panel being on, more likely to be the engine bay relay or a semi-conductor failure in the BSI
Not sure what year the car is, so here are the 2 diagrams to help you out.
jojojo
PostPosted: Mon Dec 22, 2014 6:26 pm Up
Thanks macca . I'm pretty sure it was live and fed up of my battery being dead in the morning.. ill tell my friend (mechanic) about the engine relay etc and thanks for the diagrams. It is a pre flexed.
