Posted: Fri Jan 02, 2015 2:33 pm |
This peugeot gti 180 engine is a pig to repairthey are so hard to work on
| black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust | |
Posted: Fri Jan 02, 2015 6:11 pm |
Big engine in a small car ..
try getting a 4-1 manifold down the back of the engine(gti) .
Ive got ptsd from doing it !
Pug 180 & i cannot even get the manifold clamp undone to put the de-cat on .
( funny angle &(2) heat shield's in the way . Ordered a new spanner & a long socket ready for round 2 ! i do struggle .
| If it aint broke dont fix it ! | |
Posted: Sat Jan 03, 2015 2:14 am |
Try to do top end rebuild plus timing belt
Posted: Sat Jan 03, 2015 3:24 am |
Manifold is easy if you lower or remove the subframe.
Posted: Sat Jan 03, 2015 11:59 am |
Done cambelt . Nightmare for access... not much room to move the engine across .
I lowered the subframe& engine (edward) as much as i could (brakelines in way ) .
Did not want to remove the subfame as i only had that day to do it myself over a borrowed pit .. took me 7 hrs to complete with cat welded up to with a flange .
Good luck gaznandrea . a wee polish to head valves before its refitted ?
Posted: Sat Jan 03, 2015 1:51 pm |
Flipping got wrong head bolts shop ordered wrong ones
