Posted: Sun Jan 04, 2015 3:33 pm |
Its a 06 Reg 206, like to know how to take off the passenger side wing?
Many thanks,
Posted: Sun Jan 04, 2015 3:42 pm |
well I will try to describe it as much as I can,you have to unscrew the bolts on the top of the wing,3 bolts i think.and there is one behind the headlight,it's better to take off the headlight,and also the bumper must be off the car,and there is a bolt on the down side of the car,that all i can remember now,if you are not in a hurry,I can take pics show where all the bolts need to be off so u can replace it,let me know
Posted: Sun Jan 04, 2015 4:12 pm |
| Timon2210 wrote: |
| well I will try to describe it as much as I can,you have to unscrew the bolts on the top of the wing,3 bolts i think.and there is one behind the headlight,it's better to take off the headlight,and also the bumper must be off the car,and there is a bolt on the down side of the car,that all i can remember now,if you are not in a hurry,I can take pics show where all the bolts need to be off so u can replace it,let me know |
Yes that would be great if you got the pics. If you can PM me the pics or post here it would be fab
Posted: Sun Jan 04, 2015 5:40 pm |
Posted: Sun Jan 04, 2015 6:35 pm |
Thanks but do I have to remove the bonnet and the bumper for the wing though?
Whats the easiest way to remove the wing?
Posted: Sun Jan 04, 2015 7:26 pm |
no you don't need to remove the bonnet or the bumper but the bolt that connects wing to bumper is the worst give it a good soak in WD40 and just take your time.
Posted: Mon Jan 05, 2015 6:29 am |
Does the headlight has to come out though?
Posted: Mon Jan 05, 2015 7:56 am |
| very_452001 wrote: |
| Does the headlight has to come out though? |
Depends on how skilled you are with the tools, I've changed both wings before without removing the headlamps.
Posted: Mon Jan 05, 2015 3:31 pm |
Ok many thanks
