Posted: Tue Jan 06, 2015 10:57 am |
Hello,
Recently I've noticed my idle dipping from 900rpm to 700rpm - only when cold it happens.
Is this an EGR issue?
Cheers
Posted: Tue Jan 06, 2015 11:25 am |
Is this when stationary or when moving?
If it does it whilst coasting then it's the clutch switch.
If it does it when not moving I would get some diagnostics on there to see what is going on as it really could be anything.
Posted: Wed Jan 07, 2015 5:24 am |
stationary.
Not EGR then?
Posted: Wed Jan 07, 2015 8:16 am |
You could try unplugging the Egr down the back of the engine to see what happens but you WILL get lots of fault codes so you will need Peugeot Planet to clear them all.
If you bring it to me I could probably figure it out.
Posted: Wed Jan 07, 2015 10:21 am |
It's not causing me any issues, as it's not stalling or anything.
Bit far to drive if i'm honest mate.
Cheers for the offer anyway.
