Online Now [107]:
Visitors: 106
Today: 80447
Total: 117543923
Forums › The Car › 206 Problems › need help to find airbag module
Go to page 1, 2, 3  Next
cat41
PostPosted: Thu Jan 08, 2015 7:15 am Up
Hi all, can anyone tell me where the side airbag modules are on my gt.
Just been told they may be in the doors but not sure.
PostPosted: Thu Jan 08, 2015 7:45 am Up
All AirBags share the same module,which is located under the ashtray in the center console.
PostPosted: Thu Jan 08, 2015 7:58 am Up
Side airbag units on a NON plexed 206 like this will be bolted to the sills.
One airbag ecu on each side hidden under carpet along sill, front seat out job, pull up door rubber bottom edge then unclip carpet edge - silver box with orange plug is what your looking for.
Main front airbag & seatbelt ecu is under front ashtray.
Non plexed 206s with side airbags have a total of 3 airbag control units.
cat41
PostPosted: Thu Jan 08, 2015 8:05 am Up
Ohh bum, seats out job grrr, looks easy to be honest lol. Any way thanks for that info.
PostPosted: Fri Jan 09, 2015 6:40 am Up
I will always keep learing,from a great a teacher like you Very Happy
cat41
PostPosted: Fri Jan 09, 2015 6:49 am Up
Is there side airbag modules the same on each side, so buying a left or right will fit both sides, i,m sure peugeot wouldn't make a right module just for the right side, hope you get what i,m on about lol.
PostPosted: Fri Jan 09, 2015 7:42 am Up
Send me the VIN of your car,I will see if I can check it for you
cat41
PostPosted: Fri Jan 09, 2015 8:38 am Up
Is the vin number in the window, front one, if it is its this, vf32crfrf, 40468034.
If you can get uts module part number ut be great x.
cat41
PostPosted: Fri Jan 09, 2015 8:51 am Up
Just out of interest, on the odd day the side airbag light stays of, the next day it will come on, it was sorted but i had to get out the way of an ambulance, i hit a small man hole cover, straight away the light came on. Under the left seat the wires was damaged so it was sorted and all ok but that dam ambulance made it come on. I blame the nhs lol.
PostPosted: Fri Jan 09, 2015 9:09 am Up
If it needs a replacement side airbag ecu I might be able to help you
cat41
PostPosted: Fri Jan 09, 2015 9:11 am Up
I,ve seen them on ebay for 9 quid, i,m just waiting for the part number.
PostPosted: Fri Jan 09, 2015 9:33 am Up
Well the VIN you gave me is Invalid,please make sure of it
cat41
PostPosted: Fri Jan 09, 2015 10:19 am Up
The number is in the front window at the bottom.
VF32CRFRE.
40468034
Ohh just notnoticed i put a wrong letter in, blond moment.
PostPosted: Fri Jan 09, 2015 10:32 am Up
It's ok,no problem Smile
The Part Number of the module is : 8216.L8
and this info. what matters for you when you look for a used one
Boitier SAC
Supplier/Manufacturer: Autoliv
Part Number: 550 66 10 00
(9643400480 Pout T10 AR)
Hope that helps Smile
cat41
PostPosted: Fri Jan 09, 2015 10:35 am Up
Ohh great many thanks, hope this works, it goes in for an mot on the 30th so its flat out lol, not good.
Page 1 of 3
