Latest: Beduff1977
Overall: 17134
Online Now [146]:
Visitors: 145
Today: 72837
Total: 108595974
Forums › The Car › 206 Problems › What obd2 reader??
What obd2 reader??
Sam7000
PostPosted: Thu Mar 06, 2014 5:57 am Up
I have got a pug 206 1.4 8v on an (x) reg (2000).
I have been looking on amazon at budget obd2 readers under £25 & wonderd if any one can suggest one that will deffo work on my pug 206 1.4 8v (x)reg (2000).???
Thank you
PostPosted: Thu Mar 06, 2014 6:08 am Up
I've got an Autel Maxiscan MS509. It will pull off DTC codes but won't read any live data on my 206. Works fine on later cars though.
My 206 is a December 2000 build.
Mr-Tigger
PostPosted: Thu Mar 06, 2014 6:18 am Up
if you go on ebay and search for proscan obd tool. i got one for bout 12quid. has read every car except a focus rs turbo so far, does live data and you get lifetime updates via t'interwebs aswell. its a green one with four main buttons in a diamond formation on front
Conners300983
PostPosted: Thu Mar 06, 2014 2:23 pm Up
I use a d900 bought from eBay for about £15, it will only read engine faults ie, no airbag or abs codes but will give you a limited bit of live data and also reads manufacturer specific engine codes which some other cheap units struggle with. Obviously it doesn't compare with the high end stuff (snap on, launch etc) but for 15 notes it's handy to have laying about.
Sam7000
PostPosted: Fri Mar 07, 2014 2:22 am Up
Iv used a d900 & it didn't work on my pug 206 1.4 8 v (x) reg,year 2000.
Thanks anyway!!!
gazza82
PostPosted: Fri Mar 07, 2014 3:28 am Up
Petrol-engined cars before January 2001 could use all manner of diagnostics. After that is was mandatory for European cars to be EOBD compatible .. not OBDII/OBD2 as this is US version. They may work, they may not or they may appear to work and send the wrong codes back!
If the car was new and being introduced in 2000, they should also be EOBD.
As the 206 was introduced way before that, only the models after 2001 would be.
PS Diesels switched 2003/2004.
my1st206
PostPosted: Thu Mar 13, 2014 3:18 pm Up
I use an ELM327
www.ebay.co.uk/sch/i.h...h&_sacat=0
with my Android phone with an app called Tourque Pro
play.google.com/store/...owl.torque
never let me down Smile
just dont drive around with it left in.
2003 1.1 Look
206gt160
PostPosted: Thu Dec 11, 2014 3:58 pm Up
Why will my 206 Gt not link with my maxiscan ms509?
Do the 99 reg 206's just not link with obd2 readers?
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
gazza82
PostPosted: Fri Dec 12, 2014 9:57 am Up
Not reliably .. because 99 206's are not fully obd2 compatible .. they use a hybrid PSA software.
OBD2 or OBDII is actually the US variant and only cars built or exported to US had to be compatible .. later we had the EOBD system (european which was closer to OBD2 but again, not quite .. )
To get a proper reading you'll need a Peugeot compatible code reader (Sealey do one) or PP2000 and the Lexia-3 cable system.
206gt160
PostPosted: Fri Dec 12, 2014 12:16 pm Up
I will check the sealey website cheers for the reply
PostPosted: Fri Dec 12, 2014 1:15 pm Up
Peugeot Planet Wink
Treat yourself, its nearly xmas Laughing
206gt160
PostPosted: Fri Dec 12, 2014 1:54 pm Up
Are they all chinese copies.. or is there a legit site to source the
PostPosted: Fri Dec 12, 2014 2:26 pm Up
There ALL clones unless you buy direct from Peugeot / Citroen OR Actia Wink
Make sure the interface is flashed to revision C Wink
Doesn't matter on a 206 BUT if you want to use it on newer PSA products OR use Diagbox you really need revision C firmware on the interface.
206gt160
PostPosted: Sat Dec 13, 2014 2:43 am Up
Thanks for the info I will try and get hold of one with instructions the last one I had didn't have any.
gazza82
PostPosted: Sat Dec 13, 2014 3:57 am Up
I got my kit from AliExpress but didn't use the software .. downloaded that from peugeotforums ....
