Latest: jackrox1992
Overall: 17186
Online Now [714]:
Visitors: 713
Today: 142610
Total: 147856764
Forums › The Car › 206 Talk › Intermittent Key Fob
Forum Index › 206 Talk
Spotfist
PostPosted: Thu Jan 08, 2015 1:56 pm Up
Hey all, I have spent ages trying to find out a solution for this and posted some questions on here in other topics that might not be the right place.
When I push the key fob button (two button type) sometimes my central locking kicks in and other times it doesn't. I have tried different locations, distances etc but it seems really random. Sometimes I can spend AGES trying to unlock or lock the doors and have to use the key in the door.
I have found some places on line that will repair the key but am not sure if it could be the sensor in the car, does anyone know how i would test and has anyone used these repair places and had any issues?
PostPosted: Fri Jan 09, 2015 6:46 am Up
Well this can be caused by 2 reasons,maybe a faulty remote control (transmitter),or the receiver antenna fixed around the ignition barrel.
Spotfist
PostPosted: Fri Jan 09, 2015 8:43 am Up
Cheers for the reply, any idea on how to test which one it is? I don't want to send the key away to be fixed if it doesn't have an issue Sad
PostPosted: Fri Jan 09, 2015 9:36 am Up
if the antenna is faulty,that will appear in diagnostic using pp2000,but about the key,it can be checked in a locksmith store,as they have gadgets that check the signal when you press on the key buttons.
Spotfist
PostPosted: Fri Jan 09, 2015 2:36 pm Up
Legend Timon! i will get the key tested at our local locksmith tomorrow, thanks for the idea Wink Will keep you posted.
PostPosted: Fri Jan 09, 2015 3:26 pm Up
Thank you,I hope that I help you as much as I can,good luck.
Cheers,
Tim
PostPosted: Sun Jan 11, 2015 11:50 am Up
Any Updates? Smile
Spotfist
PostPosted: Sun Jan 11, 2015 3:18 pm Up
Ye the locksmith said "Oh the main dealers took all that kind of work from us" and suggested I go to peugeot, but i was going to see if i can try a few other locksmiths first. There is one that specialises in cars.
PostPosted: Sun Jan 11, 2015 3:22 pm Up
Mmm...that is not good news..hope the one left can do so..good luck.
