Posted: Sun Jan 11, 2015 3:42 pm |
Rebuilt top end totally new timing belt fitted started up anti pollution fault came up and went into limp mode was running on two cyclinders before all this happened would this clog catalytic converter as checked spark plugs prior to rebuild they were very sooty
| black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust | |
Posted: Sun Jan 11, 2015 4:29 pm |
Why did you rebuild the cylinder head for a misfire? Get the codes read on a side note.
| Team Impossible Possible
Posted: Mon Jan 12, 2015 12:07 am |
Blown two exhaust valves so replaced all eight and skimmed head then rebuilt ans changed timing belt at same timed it up got it running now got this problem
Posted: Mon Jan 12, 2015 12:30 am |
Got codes read p1160 came up cleared it went for drive soon as go over 3000 re s same thing happens goes into limp mode same code comes up
Posted: Mon Jan 12, 2015 12:43 am |
Inlet valves faulty ? Throttle body all ok ?
Bats fully charged ?
| If it aint broke dont fix it ! | |
Posted: Mon Jan 12, 2015 6:22 am |
