Latest: jackrox1992
Overall: 17186
Online Now [950]:
Visitors: 949
Today: 116144
Total: 148878452
Forums › The Car › 206 Problems › engine runs lumpy
engine runs lumpy
DrunknMonkey
PostPosted: Sat Jun 01, 2013 1:23 pm Up
Hi everyone. I have a 206 gti that runs lumpy after it has been on a run, or if I'm on a run and have to stop and re-start. When i changed the spark plugs the No1 chamber had oil on the plug and in the plug sleeve. Someone told me that the oil on the plug is causing the car to arc and run lumpy. Any idea's on how to cure the oil problem ???
Please help
Project2062014
PostPosted: Mon Jan 12, 2015 2:47 am Up
Maybe the rings are worn on the piston letting oil throu .
Is there blue smoke coming out the exhaust pipe burning oil ?
Inlet/ outlet valves seals gone ?
