Online Now [287]:
Visitors: 286
Today: 69557
Total: 105963528
Forums › The Car › Request a how-to › fitting alloy bottom/crank pulley
Forum IndexRequest a how-to
andy83
PostPosted: Fri Jan 16, 2015 9:45 am Reply with quote Up
hi everyone i will be fitting the alloy crank pulley tomorrow i was just wondering if the pulley is connected to the timing belt or not?
any advice always appreciated
PostPosted: Fri Jan 16, 2015 11:21 am Reply with quote Up
No. On mine the pulley is held on with 4 bolts. It doesn't interfere with the timing belt pulley behind it.
andy83
PostPosted: Fri Jan 16, 2015 11:25 am Reply with quote Up
edward your a star mate thanks for that i can get cracking with it tomorrow along with doing the rear brakes and fluid change Smile
PostPosted: Sat Jan 17, 2015 3:42 am Reply with quote Up
It may on yours if you have a single bolt holding it
  Quick Reply
Username:
Message:
Quote the last message
