Latest: Kifi69
Overall: 17183
Online Now [676]:
Visitors: 675
Today: 158809
Total: 143998781
Forums › The Car › 206 Problems › 206 bottom pulley removal
Imelliot
PostPosted: Wed Jan 28, 2015 2:35 pm Up
2.0 hdi 90 2001
is there a locking pin? It isn't coming off with the air gun
DREWDEN
PostPosted: Thu Jan 29, 2015 6:48 am Up
If you mean the crankshaft pulley, you have to lock the flywheel/driveplate ring gear, using a special tool, attached to the bellhousing flange, and the ring gear teeth.
This is to stop the the pulley turning. (Haynes Manuel)
206 2ltr Hdi glx 53 plate
Imelliot
PostPosted: Thu Jan 29, 2015 12:34 pm Up
Thanks, Yes it was the crankshaft pulley. I got it in the end whit a breaker bar by putting it into 5th and pressing the brake
