Latest: airmastertapes
Overall: 17133
Online Now [80]:
Visitors: 79
Today: 46589
Total: 106907161
Forums › The Car › 206 Problems › My Indicator goes off when it likes
Townie93
PostPosted: Mon Feb 02, 2015 4:09 pm Up
My Indicator goes off when it likes could it be a Bad Earth problem or something else ? and could i fix it myself
Project2062014
PostPosted: Mon Feb 02, 2015 4:31 pm Up
Buy a new indicator stalk off fleabay for 21 squid .
check its the right one . Yours is broken !
gazza82
PostPosted: Mon Feb 02, 2015 5:27 pm Up
Pre-plex or multiplex ... Latter can't be changed ... Complete COOM2000 unit needed.
Spotfist
PostPosted: Tue Feb 03, 2015 6:54 am Up
I had the same problem an my 1999 GTI, left indicator kept coming on by itself. I found this
philsworkbench.blogspo...epair.html
Did it myself and it was really easy, just make sure you get yourself some TORX screwdrivers unlike the bellend who previously owned my car and attempted to take apart the steering column with a Phillips and a hammer! I got these.
www.toolstation.com/sh...Set/p17579
I didn't disconnect the battery either.
PostPosted: Tue Feb 03, 2015 1:22 pm Up
I also did the same repair on my daughter's 'W' plate 206. Quite simple but not so easy (apparently) on later cars with multiplex.
