Latest: lio94
Overall: 17181
Online Now [99]:
Visitors: 98
Today: 46101
Total: 141296448
Forums › The Car › 206 Talk › 206 RC/GTI 180 bellhousing matching 405 MI16 Bellhousing
Go to page Previous  1, 2
macj
PostPosted: Mon Feb 16, 2015 3:00 pm Up
206gt160 wrote:
What are the issues with the electrics on the 4 wheel drive system, also are there any other issues/weakness'. I didn't know they did a 4 wheel drive system. How good would a 4 wheel drive 206 Gti be! By the sounds of things it would be a bad idea though wih using this system
Bump
Its the fact it wont take any sort of power for long.
206gt160
PostPosted: Mon Feb 16, 2015 3:04 pm Up
Cheers Macj, has no one tried to solve these issues. Is it the diff that shatters? Or transmission shaft weakness? Interested to learn the faults of the system
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
macj
PostPosted: Mon Feb 16, 2015 3:10 pm Up
I think the description given earlier sums it up..... made of chocolate
206gt160
PostPosted: Mon Feb 16, 2015 3:29 pm Up
I will do some research and find out what parts are made of chocolate, I will post it up when I find out.
macj
PostPosted: Mon Feb 16, 2015 3:32 pm Up
you have a PM
206gt160
PostPosted: Mon Feb 16, 2015 3:38 pm Up
PM replied to
shaunbrook7104
PostPosted: Wed Feb 18, 2015 12:13 pm Up
Hey guys cheers on the feed back. I have been looking around for the T16 transfer box as its more bulky but then if I use the MI16 transfer box there are no electrical wizardry tasks to be done :/
I was just browsing pictures of the bell housing online and it seemed to similar so I got in touch with Spoox. The main issue I would have is going from cable to linkage!
The second would be going from a hydraulic clutch to a cable clutch. Unless you can change the fork inside the bell housing from a pull type fork to a push type fork?
Its just out of curiosity I am researching this and to see if it could actually be done in theory. I would have to spend alot of time getting the transfer box in and fitting the exhaust all in the recessed fire wall which is slightly off putting haha
whats the thoughts guys?
macj
PostPosted: Wed Feb 18, 2015 2:20 pm Up
This has been done with the sierra cosworth 4x4 running gear in a Puma shell. I think the whole floor pan was used. For sure it would be possible with a 206 using the Escort cosworth but why bother. If you could get a sierra shell shortended and made to fit it would be a very good effort.
PostPosted: Wed Feb 18, 2015 3:46 pm Up
That much effort i wouldnt entertain it unless you had money to burn!
By far cheaper to fit a 206 shell to a cosworth floor pan and work from that
Oafie
PostPosted: Wed Feb 18, 2015 4:50 pm Up
Dimma converted a 206 to four wheel drive by welding a cossie floor pan in and using all ford running gear years ago so it is doable. why not use audi tt running gear? more usable, reliable and easier to get hold of.
macj
PostPosted: Wed Feb 18, 2015 4:53 pm Up
PEC in Essex were going to do it but I think they have the wide arch shell up for sale now
Page 2 of 2
