Latest: Beduff1977
Overall: 17134
Online Now [435]:
Visitors: 434
Today: 277599
Total: 109843862
Forums › The Car › Request a how-to › REQ: How To replace dynamic tensioner 206 GTi + A/C + PS
Forum IndexRequest a how-to
Gumpy54
PostPosted: Mon Feb 16, 2015 11:02 am Reply with quote Up
As title, Does anyone have a pictorial tutorial on how to remove / replace the auxiliary belt tensioner pulley on a 1999 206 GTI with AC and PS??
I bought a new one as my 206 has shredded 3 aux belts in as many weeks, but I cant find the bolts to remove to fit it.
Any help would be greatly appreciated.
PostPosted: Mon Feb 16, 2015 12:24 pm Reply with quote Up
There are only two or three bolts...can't be that hard.
macj
PostPosted: Mon Feb 16, 2015 2:16 pm Reply with quote Up
is it the one with the peg holding the tension off? IIRC there are only two bolts and fir belt..... pull pin out and run Shocked
Gumpy54
PostPosted: Mon Feb 16, 2015 2:28 pm Reply with quote Up
True, I'm sure its not brain surgery, but I'm looking up the side of the pulleys looking for the two bolts to undo and can't see them. Does it have to be tensioned back to get to them?
macj
PostPosted: Mon Feb 16, 2015 2:32 pm Reply with quote Up
not that I am aware of. Take the 14mm bolt out of the middle of the tensioner
Gumpy54
PostPosted: Fri Mar 13, 2015 6:36 am Reply with quote Up
Removed just the pulley and replaced it with the nex pulley. Working fine and so much easier than removing the whole tensioner unit.
Thanks for the advice Smile
PostPosted: Fri Mar 13, 2015 4:55 pm Reply with quote Up
There you go...two bolts hold it in place.
  Quick Reply
Username:
Message:
Quote the last message
