Latest: jackrox1992
Overall: 17186
Online Now [453]:
Visitors: 453
Today: 153395
Total: 148097841
Forums › The Car › 206 Problems › 206 1.4 2005 uneven idle why??
raa57
PostPosted: Sun Feb 22, 2015 10:05 pm Up
Seems to be worse the colder the outside air temp.
206 uneven idle why??
cainw1
PostPosted: Mon Feb 23, 2015 2:19 am Up
It says the video is private.
Is this just when the car is warming up?
raa57
PostPosted: Mon Feb 23, 2015 8:20 am Up
Hi Cainw
No it seems ok when it starts from cold.in the video the car has just stopped after driving 55 miles.
It doesnt seem to do it all the time,as in after the video i stopped it for 30mins then started it up and it idled fine but after driving a couple of miles came to a roundabout an it was doing it again..
not 100% sure but it seems worse when the outside air temp is colder
Will try and sort the private video issue
Thanks Terry
Edit video should be public now
DeadEyePaul
PostPosted: Tue Feb 24, 2015 5:06 am Up
Its definitely a idle control fault. It could simply be a sensor or the whole unit? But I would take it to a peugeot specialist so they can see if the ecu has stored a fault...
PostPosted: Tue Feb 24, 2015 11:13 am Up
You don't need a specialist to check for ECU fault codes. A fault code reader is as little as £10 on ebay or from other places.
If you are reading codes some may be old and unrelated. So:-
1) Read and note the codes.
2) Clear the codes.
3) Take the car for a run from cold and see what codes (re)appear.
4) Work from the new codes.
No one should be recommending taking a car to a specialist to have engine fault codes read. You will pay anything from £30 - £65 and a reading codes is simple.
If you search the net you will find the list of codes and what they mean. It is simple.
