Posted: Fri Mar 06, 2015 9:19 am |
Is this just a faulty o2 sensor ? ![](http://i1374.photobucket.com/albums/ag435/benjv85/Mobile%20Uploads/Screenshot_2015-03-06-12-13-53_zpsrlfjmnjr.png~original)
| | ![](images/spacer.gif) |
| If it aint broke dont fix it ! | |
Posted: Fri Mar 06, 2015 10:55 am |
try disconnecting the battery for 30 minutes to reset everything before you go that route
Posted: Fri Mar 06, 2015 11:27 am |
johnpidge wrote: |
try disconnecting the battery for 30 minutes to reset everything before you go that route |
It resets only to return the faults .
I have changed the lambda sensor pre cat only a week 10 days ago ..
reason was the thread had gone and blew out the pipe .
I'm going to change the sensor I think.
Posted: Sat Mar 07, 2015 10:58 am |
It's a faulty Lambada sensor,needs to be replaced,as the heater in that sensor is not working.
Posted: Sun Mar 08, 2015 8:06 am |
or check the contacts / wiring. Measure if there is a voltage on the heater terminals of lambda sensor.
maybe there is a fuse blown that supplies lambda sensor with voltage for heating.
Posted: Wed Mar 11, 2015 6:41 am |
New senor bosch all works well .
Posted: Fri Mar 13, 2015 2:03 pm |
Project2062014 wrote: |
New senor bosch all works well . |
Glad that you got it fixed,always buy a good brand when it comes to such important items ![Wink Wink](images/smiles/icon_wink.gif)
