Posted: Tue Mar 10, 2015 12:14 pm |
I have only spare key and central locking does not lock,so boot open all the time.What can i do???
Posted: Tue Mar 10, 2015 2:33 pm |
Pull off the boot trim and lock it manually by sliding the white lever across on the solenoid
You will have to lean in to unlock it though
| Team Impossible Possible
Posted: Tue Mar 10, 2015 3:06 pm |
I have noticed a difference during the 2003 model year.
Both my 206's are hatchback & have remote deadlocking factory fitted.
My February 2003 built 206 has this tailgate locking solenoid motor where you can slide the white rod across to lock it.
My October 2003 built 206 doesn't, you have to unclip the metal rod between the tailgate handle & the tailgate latch to stop it opening.
Posted: Wed Mar 11, 2015 2:39 pm |
What's the worse possible scenario with this? Is it electric bits, or a expensive job? Gonna call pugbitz tomorrow. Any advice?
