Latest: flipflap
Overall: 17140
Online Now [87]:
Visitors: 86
Today: 48622
Total: 113795840
Forums › The Car › Solved 206 Problems › Removing HID kit from Morettes?
JordHaze
PostPosted: Thu Apr 02, 2015 5:45 am Up
Hey guys,
Just bought some morettes with a HID kit and was wondering what the process is of removing the HID and putting in the H1 bulbs again. Is it just unplug or is it hardwired in?
I'm have a lot of trouble with the HID and just want regular lights if possible.
Cheers,
Jord
My 206 Project Thread
Carlos_WR1
PostPosted: Thu Apr 02, 2015 7:11 am Up
What sort of problems are you having with the HIDs? I have HIDs on my car and fitted them myself so if i can help at all, would be happy to.
JordHaze
PostPosted: Thu Apr 02, 2015 7:15 am Up
Passenger side - works fine.
Drivers side - nothing.
I'm trying re-wiring the ground as the guy I bought them off said he was having a few problems with it, if that doesn't work, I'll just take the kit off and stick some OSRAMs in there instead.
Didn't want HIDs, but as they were free I may as well have done Razz
Carlos_WR1
PostPosted: Thu Apr 02, 2015 9:54 am Up
could be a ballast issue?
Without seeing how the previous owner wired them up, it would be difficult to say what the problem is. If you did decide you want to keep them and need any help, just let me know.
JordHaze
PostPosted: Thu Apr 02, 2015 12:10 pm Up
Fixed now, it was one bulb in the wrong way round messed up the whole circuit.
JordHaze
PostPosted: Fri Apr 03, 2015 11:12 am Up
Okay, now the other side's ballast has stopped working. Is it worth the hassle?
copey
PostPosted: Fri Apr 03, 2015 11:46 am Up
just buy a new set for bout £25 and you know they right then
02 2.0 hdi d turbo
Carlos_WR1
PostPosted: Fri Apr 03, 2015 1:15 pm Up
I would just buy new ballasts, should be able to pick them up for around £15 for a pair.
I would say it is worth it as a lot of people moan that the morettes are very dull with normal bulbs.
Carlos_WR1
PostPosted: Fri Apr 03, 2015 1:19 pm Up
Justa word of warning though, ballasts can come in 55w or 35w i cant remember off hand if you have to match the ballasts to the bulbs.
Id still be keen to see pics of how they have been wired as it could be something as simple as a wiring issue.
Also have you checked your fuses to make sure you havent blown one when connecting up the new lights?
PostPosted: Sat Apr 04, 2015 12:06 pm Up
I would argue otherwise. I have Phillips extreme 100% bulbs in my morettes and visibility isnt an issue at all. Given the design they will never be as good as standard lights but unless you're doing midnight rallying, standard bulbs arent an issue in morettes IMO.
