Online Now [525]:
Visitors: 524
Today: 6532
Total: 106200765
Forums › The Car › 206 Problems › CD Player problem
CD Player problem
Geforce
PostPosted: Thu Mar 19, 2015 3:05 pm Up
Hi guys, I have a factory Peugeot 206 CD player but the discs will only play when the engine is off, as soon as I start up it stops playing the disc.
Any help please
tRiCk
PostPosted: Thu Mar 19, 2015 8:32 pm Up
Could be the wiring has been changed behind the radio and is no longer correct for the standard radio. Pull it out and have a look.
Geforce
PostPosted: Thu Mar 19, 2015 11:58 pm Up
What am I looking for if I pull it out? I'm a novice
PostPosted: Fri Mar 20, 2015 3:28 am Up
Good job this is a family friendly forum as you could get many answers and graphics in response to this Laughing
What year is the car? Might just be a case of moving a fuse.
Is the radio having the same problem?
As tRick says might just be the wiring. If the previous owner had an aftermarket HU fitted then they will have swapped the Red and Yellow wires to power it. When they have put the original HU back in they haven't changed the wiring back.
If they have done a bodge job, then it will be pretty obvious what you're looking for once you pop the HU out. If they have done it properly then you may need to get a multimeter out and check the feeds.
Geforce
PostPosted: Fri Mar 20, 2015 6:16 am Up
Its a 2000 model. And the radio works fine.
