Latest: Worthy967
Overall: 17143
Online Now [789]:
Visitors: 788
Today: 41588
Total: 115072882
Forums › The Car › 206 Problems › New Head Gasket
New Head Gasket
JordHaze
PostPosted: Thu Mar 19, 2015 7:41 am Up
Hey guys,
I have quite a substantial oil leak from my engine bay.
I've decided it's probably from my head gasket.
How much would it be to get it fixed?
Cheers,
Jord
My 206 Project Thread
oldskoolz
PostPosted: Thu Mar 19, 2015 7:51 am Up
JordHaze wrote:
Hey guys,
Cheers,
Jord
Depends on what engine and where you take it. By the book its about 4-5 hours, although I've witnessed one done in less than an hour Shocked
Oil leak doesn't neccessarily mean head gasket has gone, usually oil or water loss would be more the symptons you would be looking at.
If its a TU engine (1.1 1.4 1.6 8 valve engines) then they do tend to leak abit of oil and I wouldnt worry too much.
Black 206 Gti. Soon to be 2.2
JordHaze
PostPosted: Thu Mar 19, 2015 7:54 am Up
oldskoolz wrote:
JordHaze wrote:
Hey guys,
Cheers,
Jord
I've got a 1.4 16V. The leak is almost a stream and it's when I first start up and when I slow down. I work 8 1/2 hours a day so I can't get it to a garage until the weekend.
Carlos_WR1
PostPosted: Thu Mar 19, 2015 7:59 am Up
Can you see where the leak is coming from? You sure it isnt a rocker cover seal gone?
Have you checked the oil filler cap to see if there is any creamy residue?
JordHaze
PostPosted: Thu Mar 19, 2015 8:00 am Up
Can't see where the leak is coming from, there's no creamy residue, but yeah it could be a rocker cover seal
lip_88
PostPosted: Thu Mar 19, 2015 8:05 am Up
Could be a cam or crank seal find the source before throwing money at it mate
oldskoolz
PostPosted: Thu Mar 19, 2015 8:30 am Up
JordHaze wrote:
oldskoolz wrote:
JordHaze wrote:
Hey guys,
Cheers,
Jord
A stream? From where?
Pricewise I wouldnt expect any change from £250 as an absolute minimum.
oldskoolz
This ^
Most common oil leak is rocker cover gaskets
David1156
PostPosted: Thu Mar 19, 2015 8:50 am Up
This ^
Ditto. My 1.1 is/was leaking from the rocker cover. Have you checked for any blue smoke coming from the exhaust?
Current: Albi Blue Clio 197
PostPosted: Thu Mar 19, 2015 5:37 pm Up
Ive seen a stream before on an et3, and ive managed to remove a head in 30 minutes, but never back on in and running in an hour though!
If your not sure, do the camseals, and rocker gasket
PostPosted: Thu Mar 19, 2015 5:38 pm Up
I do beg to differ on the rocker cover leak...
The headgasket is the most common failure on a TU
