Latest: lio94
Overall: 17181
Online Now [123]:
Visitors: 122
Today: 106222
Total: 140451846
Forums › The Car › Solved 206 Problems › Starting problem with my View plate 206GTI
Emerald
PostPosted: Thu Mar 19, 2015 4:52 am Up
hi there!
I'm new to this site and hoping can get bit of help?
My 206 has developed a starting problem, now have to blip the throttle while turning her over!
Have had new spark plugs fitted, new fuel filter she's had oil change but still has problem any suggestions?! Thanks.
Carlos_WR1
PostPosted: Thu Mar 19, 2015 5:14 am Up
Have you cleaned the throttle body and also the ICV?
PostPosted: Thu Mar 19, 2015 1:14 pm Up
if you tell us more about the problem,we might be able to help you more.
Emerald
PostPosted: Fri Mar 20, 2015 10:23 am Up
Carlos, thanks for that will have that done see if makes a difference.
Timmon2210 - usually on turning key in ignition she starts no problem but over the last few weeks she hasn't started this way but instead turn key and blip the throttle to get her to start and warm her up and she runs fine?!?
PostPosted: Sat Mar 21, 2015 12:41 pm Up
Well it's time to clean your throttle body,and Idle control valve,then you will have it back to normal Smile
Emerald
PostPosted: Sat Mar 21, 2015 7:09 pm Up
Thanks Timon2210, will get her booked in this week and hope isn't too costly!
Will do Timmon! will find out today when i get her back! Smile
PostPosted: Fri Mar 27, 2015 2:35 am Up
Please update when you have the final result,so it can help other members in the future Smile
