Online Now [579]:
Visitors: 578
Today: 149626
Total: 106486799
Forums › Welcome › Frequently Asked Questions (FAQ) › swapping brake discs?
Forum IndexFrequently Asked Questions (FAQ)
Horton898
PostPosted: Fri Mar 27, 2015 11:17 am Up
Im sure ive seen a thread about this before but cannot seem to find it. I bought a set of vented discs for the front of my 206 but my car has solid discs, is it possible to straight swap them or are the calipers different for vented discs? Thanks!
PostPosted: Fri Mar 27, 2015 11:44 am Up
Calipers are wider as the discs are thicker.
tRiCk
PostPosted: Fri Mar 27, 2015 12:29 pm Up
I have some Gti 180 disc and calioers for sale. £50 collected
Horton898
PostPosted: Fri Mar 27, 2015 2:04 pm Up
Okay thanks Edward! Trip to upullit (scrappy) it is next week then to get a couple calipers then, only 8 quid a piece plus fitting, I don't quite trust myself to bleed the brakes haha. Thanks trick but already have a set of brand new discs so just need to pick up the calipers. Cheers
