Latest: tbafonso
Overall: 17130
Online Now [51]:
Visitors: 50
Today: 202
Total: 103186805
Forums › The Car › 206 Problems › New Cat -- DIY
New Cat -- DIY
jamie-38-206
PostPosted: Sat Mar 28, 2015 10:36 am Up
Hi,
going to replace the cat myself as old. Saw a few good prices for new ones. But do I need to order any gaskets with it etc?
Cheers
206 1.4 - 2004 (TU3JP)
Vexs
PostPosted: Sat Mar 28, 2015 10:50 am Up
Im sure there is a gasket between the manifold and cat, PM me your VIN and i'll double check service box.
My GTI 180
My Old 1.4 8v
Seatock789
PostPosted: Sat Mar 28, 2015 11:50 am Up
There is a gasket between the manifold & cat, it's a thin metal one.
Check out react catalysts, they are a part of ECP.: www.reactcatalysts.co....c1LnBuZw==
Mine was included as part of the package when I bought the cat converter.
PostPosted: Sat Mar 28, 2015 11:59 am Up
Easy enough to replace yourself. 4 bolts to the manifold, one that holds the pipe to the gear box and then the 2 bolts on the clamp to the centre pipe.
The post cat lambda can be difficult to get out if it's been there a while, so might be better off replacing that at the same time if funds allow.
Buy a fitting kit and it should include the manifold gasket and nuts and the fittings including springs for the centre pipe clamp.
Don't use any exhaust paste on the manifold join. Just use the new compression gasket.
PostPosted: Sat Mar 28, 2015 1:30 pm Up
no need for a new gasket,it's metal and you can use it again :),I changed my manifold,and kept the old gasket for both manifold and CAT,and no problems what so ever.
