Online Now [517]:
Visitors: 516
Today: 1967
Total: 106131710
Forums › The Car › 206 Problems › 206 gti lower engine mount
Onzlow
PostPosted: Sat Apr 04, 2015 2:07 am Up
Hi I have a 2004 206 gti and the lower bottom engine mount which the driveshaft goes through doesn't seem to have any bolts in it? The bottom 2 bolt holes seem to line up but the top one doesn't? Any ideas why the bolts aren't there? Is there any common problems with these mounts. Thanks.
PostPosted: Sat Apr 04, 2015 3:51 am Up
You talking about the big alloy block that the shaft runs through?
Onzlow
PostPosted: Sat Apr 04, 2015 5:12 am Up
Yes
