![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › speedo odometer and alarm not working |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Fri Apr 10, 2015 1:12 pm |
Hi There and hello to everyone, I am a new user.
I have been searching lots of forums but im stuck, firstly I own a 1999 1.6i 8v 206, which I have not had for long. I knew there was issues when I bought the car, but my heart ruled my head.
Here are my issue firstly speedo and odemeter do not work, seems like they have not worked for a long time. but I have tried new dials changed sensor in gearbox checked wiring behind passenger wheel and all seems fine, but still not working.... checked fuse under bonnet seems to be fine. what else could I be looking at apart from possible drive in gearbox
Also my fob button does not work the central locking key fob flashes but nothing happens.
question is could all this be related, possible bsi problem tried reseting bsi unit but maybe I am doing something wrong
Any advise would be greatly appreciated, this is my first pug, be gentle please haha
| | ![](images/spacer.gif) |
Posted: Fri Apr 10, 2015 1:15 pm |
The alarm system ONLY arms if the remote fob is used to lock the car.
Have you tried to resync the remote fob with the car?
Posted: Fri Apr 10, 2015 1:33 pm |
tried a few different things to re sync, holding button for 20 secs whislt in ignition and then small back button. holding it up near the courtesy light. nothing, like I said all new to me so many different procedures read but not actually knowing which is the deffinate procedure for this model
| ![](themes/base/images/forums/otr.gif) |
