Latest: Puggingalong
Overall: 17129
Online Now [115]:
Visitors: 114
Today: 1403
Total: 101623433
Forums › The Car › 206 Problems › Auto shakes after clutch replacement at 70 Kmph, 25rpms
jbhensoniii
PostPosted: Sat Apr 18, 2015 4:05 pm Up
I just changed the clutch 2 months ago and has performed well since then. The clutch change got rid of a clunking noise when taking off from a stand still.
but right after changing the clutch I noticed we had a shaking after shifting into 5 gear and hitting 70 KPH around 25 to 28 rpm.
I have ruled out tires because I have had them balanced 2 times, aligned the front end, no help.
Now the car is doing it worse every time I accelerate to around 25 to 28 rpm ths whole front end of the car shakes and shimmeys.
Any ideas would be greatly appreciated! Very Happy
PostPosted: Sun Apr 19, 2015 3:58 am Up
Check your inner cv joints for dips in the where the ball runs along. This will cause your issue
mattymj
PostPosted: Sun Apr 19, 2015 3:15 pm Up
Wheel nuts all tight
jbhensoniii
PostPosted: Sun Apr 19, 2015 4:01 pm Up
Yes, had them balanced 2 different times because I thought it was the wheels too. Took the tires off then back on, tightened up completely. thing is it only happenes between 25 to 28 rpm WHEN accelerating. It doesn't happen when if you take foot off gas and idle down to that speed.
jbhensoniii
PostPosted: Sun Apr 19, 2015 4:24 pm Up
Are you saying i need to replace them?
